Displacement Problem / Triangle Mesh / Edges
Hello
Since I use Corona (for some years) I always encounter the same problem. When I use geometry provided by clients or myself I often have triangular mesh, as this is how openings are connected to the surface.
It seems impossible to avoid wrong Displacement. As you can see I am always confronted with artifacts along lines. Especially when they are close. It creates dark areas.
Is there any work-around or solution on this ?
Thank you very much :smiley:
Asimo
Hi there, Using the β€˜β€˜melt’’ function in C4D should resolve this. Select all offending faces (or the ones you want merged as one) and right-click > β€˜β€˜Melt’’. The result should look similar to my example. I hope that helps.
