Displacement problem
I have a problem, after applying a displacement map it doesn’t shows after render.
I’ve tried  to increase the multiplier and the edge length.
but when i apply the same map as a bump it works just fine.
The question is what causing the displacement to be unseen?
Re: Displacement problem
Did you group it? You must group the face you are applying the displacement to.
Oh! i totally forgot that.
thanks a lot david.
where exactly would we learn that we need to group the face that we are applying displacement to? We are currently having issues with disp. in VRfSU and the manual is certainly causing major headaches. It seems there is all this info we dont have yet.
Tutorial section doesnt have anything about displacement, whether we have to have a diffues map applied or not. what type of multiplier to select from the drop down menu below the amount of multiplier, etc.
Is there anywhere I can go to find all this info. Thanks if you can answer or point me in the right direction!
