Displacement problems
Hey guys did anyone beside me had this issue with displacement ? :
  • we 're using small tiled map on object. ( for example gravel )
  • object is uvw mapped (planar mapping)
    -displacement map and bump map are the same map.
  • bump map works good, displacement doesn’t → corona dont see mapping modifier :frowning:
You have to creat a good quad mesh.
this is very simple mesh :frowning: made of extruded box
Try subdividing you model.
For me it seems like diplacement isnt able to produce enough polys for a good looking surface.
Greetz
Lucutus
create a spline and modif. → Garment Maker —> and Displaisment .
“Garment maker” isn’t very good for subdividing flat surfaces as it sometimes does bad things to corners. Try using “subdivide”.
try this :wink:
so the more quad polys the easier for corona to generate displacement :smiley: ?
Yes, but this applies to other renderers too.
I did a quick test to demonstrate how much more efficient displacement can be with better topology:
where i can adjust maximum mesh subdivision ;> ?
Render setup>Corona Settings>Main settings>Max subdivs per poly
F10 → TAB: Corona Settings → Rollout: Main settings
You have to study better how displacement works. And not only in Corona, but also in VRay etc… Mesh topology is important in displacement :smiley:
thanks you all for your help :smiley:
