Displacement with vray RT CPU
I am trying to render displacement using a vray displacementmod with vray RT CPU but it does not work. Is there any special way to make it work?
What type of displacement? Are you using V-Ray RT as production renderer or ActiveShade?
As activeshade. And I tried every possible way with the vray displacement mode.
On the VRay RT tab there is a section named “Geometry”. Check if the displacement CheckBox is clicked.
FYI: When RT is set as production render, with the new UI, Displacement checkbox is no longer in the RT tab. Look for it in the Global Switches.
Thanks for your answers.
Ok so it works only in production mode. In activeshade there is no displacement option it the render settings.
I was able to render displacement with vray RT by checking that checkbox in the global switches (it was off by default)
but now my problem is that it does’nt seem to support bercon noise correctly. Do you think you could support it? I can see displacement with a bercon noise, but the mapping is very different. I just use the default mapping that seems to be some kind of 3D world mapping.
here is the result of a bercon noise displacing a sphere with a VRayDisplacementMod
VRay advanced:
VRayRT:
Yes, bercon maps are not supported in RT yet. It is in our “to do” list.
Ok cool. Thank you!
Excellent, is there a possibility other plugins will be supported too, for instance, VIZPARK Walls & Tiles, because this is based on BerconTile.
Let’s do the Bercon maps first and we’ll see how it goes.
Haha, sure. No pressure. Vray-users, right? Always hungry for more. SP1 has just been released and the new requests just keep on coming :wink:
