Displacement working in CPU mode not GPU
Just, wondering why I can see displacement happening when CPU mode is selected but not when GPU is enabled. It still renders in RT just with no displacement. Vraydisplacement modifier is added to the object.
Thanks for any help
Simply because it only works on the CPU for the moment :slight_smile: We do not bake the displacement like iray; instead V-Ray RT CPU uses the same dynamic memory engine for render-time displacement as the production V-Ray.
You can use the 3ds Max Displace modifier though - it will work in both the CPU and GPU modes.
