Displacement
Hi, I’m using displacement in a scene and can render up to 2.5k but it won’t render at a higher resolution. Are there any suggestions on how to optimise Vray GPU when rendering displacement?
Thanks,
N
Hi, thanks for posting. If possible start with clean, well modelled geometry. If you are using 3ds Max, go to render setup/settings/default displacement and increase the edge length parameter.
With higher numbers you will have less memory consumption and you will have to decide if the quality works for your case. Also the view dependent checker helps to lower the memory usage. Leave it on.
Please check these links as well
- V-Ray for 3ds Max
- https://support.chaos.com/hc/en-us/articles/4412959408017-Memory-Usage-Optimizations-for-GPU-rendering
