My siding uses a displacement modifier, and it looks like it is melting. It looks great on CPU and GPU. How can I get it to look good in vantage? What is the trick?
Hi Bobby,
Can you provide a screenshot of the siding? i can only guess that the tessellation is not sufficient and the sharp edges are not extruded properly. You could try to subdivide the facade geometry to help the displacement.
Alexander
I have tried, but it didn’t make a difference. I’ll post something shortly.
It’s just a guess (I don’t have a Vantage sub any more to test) but does lowering the filter mult fix it?
It’s because your mesh still doesn’t have enough subdivision per vertex opposed to per pixel (which is what you’re seeing with CPU/GPU from Max). You need to increase your tessellation settings within Vantage - which you have plenty of room for given you’re only consuming about 1/3 of what your card can handle.
Okay, I’ll give it a go. Thank you!
