displacement
can someone explain how to use displacement, normal, and bumps maps together. I guess displacement would be in the v-ray displacementmod and the bump in max’s bump slot, but what about the normal map
Normal maps go into the bump slot as well.
You can set the bump slot to ‘Normal Bump’ and then use a bump and a normal map at the same time.
bump
How would you have two maps in the same slot?
If you use the “Normal Bump” map there’s a slot for “Addtional Bump”. Put your regular bump map there.
Bump
It is true… all the smart guys are from Chicago! Thanks.
