displacment animated texture
Hi there
is there anyway to use animated textures in VrayBitmap channel ?
doesn’t seem to work
thanks best regards
nuno
Hello @nunomatos You can created Animated textures by using the Bitmap Shader. Please, refer to the video attached: http://ftp.chaosgroup.com/support/scenes/Cinema\_4D\_2024-01-10\_09-41-46.mp4
Additionally, please, make sure to use Absolute path when using this set up.
Hi @viktor_angelov thanks for your prompt answer and video. But not working with Vraybitmap shader, right? because standard bitmap shader does not allow negative colours, for example.
I’ve this product from Henrik at Figment and his tutorial shows how to use it in a deep way using exr files in VrayBitmap animated textures
thanks for clarifying.
best nuno
