Very urgent problem. We have a massive animation project with a tight deadline and realized that when trying to use network rendering through any render manager none of the display corrections are applied. The same goes for the light mix adjustments.
Please suggest a workaround… We tried exporting a LUT from VFB and use it in premiere but the the result is way off. Maybe someone can explain how to achieve this.
Also because of the light mix issue the only workaround is to send the light mix setting to scene. This is not ideal because the main file has a bunch of xrefs and as I found out during my tests the adjustments are applied only on the lights and vray light materials that are inside the main file.
If someone has a better suggestion for this please that doesn’t imply merging the xrefs please share.
You’ve posted in the wrong forum section. Post again in the correct subforum to get answers.
so sorry for this. The post can be deleted.
