Display issue
Hello-
This isn’t a v-ray issue, but since you guys are the smartest people on the planet I thought I would ask here. I just upgraded my workstation to WIN7 and although it solved a lot of my VISTA issues, it didn’t solve my graphic issues.
I have the NVIDIA Quadro FX 3700, with the latest driver. My display in MAX is awful… When I hover my mouse around the screen the display changes under the cursor. Below is how shaded things look until a zoom. Has anybody had this issue and if so have you found a solution?
are you using the max opengl or directx drivers?
I have tried both, it doesn’t seem to matter.
Turning on hardware shading solved my display issue. I can’t see the textures I am using for a blueprint, but I can toggle HW on/off pretty easly.
The HW Shader only helps in Shaded mode and doesn’t effect wireframe. In wireframe I still get the bad display problem.
I’m having problems as well, I have the same setup as you do except I have a 3800. My scenes seem to be very sluggish compared to Max 2009, I can only use Direct x 9, the Nvidia performance drivers don’t work.
Their isn’t a Nvidia performance drivers for 2011 yet and the standard drivers don’t work very well for MAX. I might need to upgrade my card… any surefire suggestions?
