When using DR I´d like to see how many passes were rendered by the master and how many by the slaves (without the need of summing up all passes in DR tab and substracting this from the number of total passes).
It´s important for example while checking the next adaptivity recalc intervall. Atm you never know when you get the next valid noise level calculated.
But independently from that I´d like to see that information in the stats.
Thanks for one of the fastest feature request implementations ever I´ve been using it now and I would like to tweak it a bit:
My epic fault was suggesting to show DR passes in the brackets not the local ones. Now still you have to do math to get the local passes (which are the most important, for the reason in the first post).
Additionally those characters (“DR:”) in the stats tab look somehow… ugly, can´t help myself. So please find attached two proposals to solve both “issues”. Either option A which shows all: sum, local, dr or if this appears to be too much option B with sum and local only. One of those two would be fantastic. Sorry for the inconvenience,
