I think a nice feature to add would be to show the distance between keyframes when creating animations. One of the hardest parts of making animations in sketchup is keeping it going at a consistent pace. I believe if the keyframes said how far apart they were you could time the keyframe accordingly.
Hey @Brookrb , could you please briefly detail where you’d like this information to be displayed? Maybe in the “Timeline” of our “Video Editor”, or in Enscape itself? Maybe you have something else in mind?
You generally want to be able to see the time it takes from one keyframe to the next, correct?
Be aware, you can also figure how long it takes from one keyframe to the next by having a look at your timestamp output:
I believe there should be something that shows the actual distance, in feet or meters, between the keyframes. I think it would go onto the keyframe editor, not as something that would require a slider, but showing how far apart each keyframe is. I believe this would help create smoother animations.
So for example I want to produce a thirty second animation around the exterior of a school. Right now I would create the path and have each keyframe be 3 seconds apart. When doing this maybe keyframe 1 and 2 are 50’ apart but keyframe 2 and 3 are 75’ apart. The animation will end up speeding up to make it work. I can adjust the timing yes, or the position of the keyframe to try to get them at the same speed. I think just knowing how far apart the keyframes are would just help smooth out the animations and maybe eliminate some back and forth that you have to do to make the animations appear as smooth as possible. Having the animation change speed can be jarring at times and make people loss focus on what we are trying to get them to focus on.
That being said, i just finished 3 different animations for a school proposal and I haven’t had a better experience creating an animation. The UI was very simple and the time it took to export the video from our firm’s alienware was extremely quick. My boss was very pleased and we are waiting to here back if we won the project or not.
