Distance Shader refresh issues in IR
Distance Shader.
The “preview text” (the red background) is upside down in the preview window (Distance: no objects) and does not change either once an object is assigned to.
Then there are some IR refresh issues.
Load the scene and run viewport IR. Select Circle.1 and move it along X. No change in the viewport. Disable the Spline Mask. The result in the viewport goes red (which is ok).
Turn the Spline Mask back on, the viewport stays red (which is not ok).
Restart the IR, all is back to normal.
Version: 6.0 daily Jul 16 2020
Win 10 2004
S22 latest
distance refresh.c4d (180 KB)
+1, I can confirm this behavior still exists in v6 (tested on Windows 10). :smiley:
Huh, we fixed this on 23/07/2020, and I cannot replace this on V6 stable version, and not in latest V7 daily.
Please check if you’re using a build from after 23/7/2020,
Jan
Hmm, I am using the Version: 7.0 daily Jan 22 2021 right here.
Gave it another shot though and I think I wasn’t quite clear enough what I +1 oned. I wanted to let you all know that the IR still doesn’t update on changing the “Circle.1” object which means that the distance shader doesn’t quite update reliably when running it with the IR.
I did mess around with other scenes and it tends to work fine although sometimes you do need to restart the IR for the distance shader to start working.
Still no refresh with the latest V7 daily.
If you switch off the spline mask and switch it back on again, you get a “blank” plane with no refreshing splines either.
Pretty much this. The way I form sentences today is just … Weird :smiley:
Right, this. Yes we have it on our to-do list but moved the priority because of more pressing issues.
Thanks for the patience,
Jan
Hi
I had another issue which seems to be caused by Corona distance shader.
Successfully uploaded as 1612625225_Issue-DistanceShader.zip
Hi, we have tried to retrieve your upload but something went wrong and the file cannot be downloaded. Could you please try to upload it again? Thanks!
Sure.
Successfully uploaded as 1612809107_Issue-DistanceShader.zip
