Hi, after the latest update, I can no longer use my two nodes.
The server license is on an iMacPro with Cinema 4D 2025.3.3, Mac OS 14.6.1, and I updated to version v7.20.00 on December 4, 2025.
The nodes are on Windows 11, and I downloaded both versions of the standalone version: V-Ray 7 Standalone, update 2.3, and V-Ray 7 Standalone, update 2.3 DR2. I can’t get distributed rendering to work with either.
What did I do wrong?
Hey, Luca,
Thank you for the report. 1/ The standalone version should be the same as V-Ray for Cinema 4D. 2/ We updated the port for DR2 to 20209, so if you have a shortcut, you should update it as well. Can you show me more info about the problem?
Cheers,
I solved the problem.
Anyway, here’s a summary of what happened.
This update didn’t update like the other times. Once it was done, if I used the usual Launch Vray Server shortcut, the old version 7.10.00 would start.
I had to uninstall all versions, standalone and Cinema 4D Plugins, and reinstall everything.
But a new problem arose: there was no longer a shortcut to launch Vray Server. I had to create a command that would launch the server version of Vray. After that, everything started again.
Thank you for the efforts, Luca.
We are aware of the shortcut for V-Ray Launch. That is already fixed in our test branches and will be in the next release. However, if you need a workaround until then, please let me know.
Cheers,
Hi, is the behavior I described above normal? I can also make a video to show you this behavior.
I am not even able to start 7.20. 7.10 was fine.
You can download our stable build, where the issue is fixed.
