So I got few problems. But lets start from main one and its basically one of nodes dont start to render. Each node is pretty much mirror of one another so they all should work. 4/5 computers work 1, Has issues and dont render. How can I troubleshoot that?
Ok so I noticed that during installation I was not asked to input license. When I try to render localy from slave it says it needs license. How can I manually input license? Maybe DR crashes because there is no license…
Max install location: C:\Program Files\Autodesk\3ds Max 2014
21/12/2010 08:24:13; Max file being rendered: C:\Program Files (x86)\Corona\DrServer/drData//received_scene.max
21/12/2010 08:24:13; Renderer: CoronaRenderer
21/12/2010 08:24:36; Render Error (Initializing Renderer)
21/12/2010 08:24:36; Error rendering frame 1: Render Error (Initializing Renderer)
21/12/2010 08:24:37; Job Completed with Error(s) - see above
21/12/2010 08:24:47; Error occured while rendering job.
21/12/2010 08:25:46;
and
2010-12-21/08:24:03 DR server started
2010-12-21/08:24:03 Cannot read the config file, default one will be created
2010-12-21/08:24:03 Creating default DrConfigA7.txt: found 1 3ds max versions
2010-12-21/08:24:03 Starting UDP socket, local hostname: s22
2010-12-21/08:24:06 Replying to discovery ping from Dariusz
2010-12-21/08:24:12 Accepted remote connection from Dariusz
2010-12-21/08:24:12 Parameters received: 2014 1
2010-12-21/08:24:12 Downloading 3ds max 2014 scene to render with 3ds max 2014
2010-12-21/08:24:13 Downloaded scene: 909,312 bytes in 0 s
2010-12-21/08:24:13 Running command:
echo Starting 3ds max DR… && “C:\Program Files\Autodesk\3ds Max 2014\3dsmaxcmd.exe” “C:\Program Files (x86)\Corona\DrServer/drData//received_scene.max” -o:“C:\Program Files (x86)\Corona\DrServer/drData//dr_out.png” -start:1 -end:1 -continueOnError -gammaCorrection:1 -rfw:1 -sf >> “C:\Program Files (x86)\Corona\DrServer/drData//MaxLog.txt”
2010-12-21/08:24:13 Replying to discovery ping from Dariusz
2010-12-21/08:24:15 3ds max is online after 2 seconds
2010-12-21/08:24:20 Replying to discovery ping from Dariusz
2010-12-21/08:24:23 Got END signal from remote side, forwarding to 3ds max
2010-12-21/08:24:27 Closed loopback connection
So i did my licences on all render slaves as in the nfo. pages but corona dr. still giving me > Got discovery ping> Replying to discovery ping from main pc?
Today i was rendering my test scene (see below) with Corona DR on 3 slaves. I try to render on region part of the scene with DR and after 2 min. i realized that DR could not work in region at least properly. I got Error and non of them working properly. After that i tried to render the scene again in Full aspect and everything was normal. Maybe that is an issue or bug.
