is it possible to keep the local CPU free while doing a render using the DR client ??
Re: distributed render but not local ?
No … but if you are working on a multicore machine, than you could set the Rhino.exe at the taskmanager so, that less CPU cores are used. This slow down the LC pass, because the LC from the master machine only is used for the rendering. But if you render a large scene, you could set down the CPU count after the LC pass is done.
Most it’s no problem here to render an image at low priority and at the same work on the machine.
