Hello. I have 1 main machine with 3 render nodes (V-ray Next 3ds Max 2020). I plan to have 2 machines in one room and 2 machines in another room. Plan to plug the 2 machines into a switch in each room (2 machines into each switch) and then run cable from switches to a router located in the hallway. Will this work or must I run cables directly from each machine into thier own port on the router with no switches in-between?
Currently I have all 4 machines plugged directly into my router with cables but I will be moving to a new building so the 4 machines will end up in 2 rooms and I will have a new router also. So I am not sure what all changes and issues to expect. I am not good at these things.
Thank you
