Distributed Render problem.
I am having a problem with start up the VRaySpawner50.exe with my machine..
It seems no error pop-up or unusual behaviour after the VRaySpawn50.exe loaded… But when I check out the log file “VRSRVLOG.txt”, It contains the lines below everytime I started up:
>> Beginsequence: About to load VRender50.dlr
>> *** ALERT! Could not load the VRender module!
Does anyone know what pieces do I missed? I checked everythings, and the VRay works fine in normal rendering process in single mode (not DR)..
mm… … :roll:
Sorry guys, :slight_smile:
I just found out the solution for this problem in the old post…
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=3212
Thanks!
