Distributed Rendering and Project settings
I’m trying to know what is the behaviour of the Max “Project” settings with Distributed Rendering.
If i set a set a custom Project folder in Max, the paths configuration (specifically the texture paths) are stored in a .mxp file. But does DR uses this configuration in some way ?
As far as i know, it doesn’t… but some of our customers are experiencing different results. It seems the maps configuration of the DR nodes (defined in 3dsmax.ini) is updated automatically when submit a DR job.
Any idea about it ?
Thanks,
Hi Carlos,
In order to have DR fully working without warning and errors for missing assets, all external files must be set to absolute paths.
Setting the 3DS Max project to a network shared folder should work. Just make sure that Asset tracking manager shows the full path to the textures folder in the Path column.
If you give us a workflow that has more specific setting, we can run few tests.
Hi Tashko,
Ok, I just wanted to confirm that V-Ray doesn’t modify the map paths, or use the .mxp files.
Thanks,
