i have some problems with the brightness when rendering in distribution mode.
While rendering i get stirpes, some parts are brighter and some parts a darker than
others. (see attached file) I checked the LUT/gamma settings in Max on all slaves, it is set to 2.2 on all
machines. What could the problem be? How can i solve this?
Thanks and best regards!
kopengo
Hi, I really don’t want this to sound bad but there are many reports of similar issues and different users needed different fixes and we haven’t come up with any “ultimate” solution yet.
First thing: which Corona version are you using? Did you try with newest daily build and newest DrServer.exe?
Especially: 2. Rendered objects are white, semi-transparent, or invisible or textures are missing
and 3. I can see dark / bright stripes in my rendering
This part: If for some reason distributed rendering does not work as expected, it is advised to check the images generated by each render node. To do so:
may be useful to determine whether this is a gamma, texture loading, or other problem.
There is also this thread:
Some of the most recent fixes suggest using “\networkname\folder name\file name” texture paths instead of “X:...” and checking the gamma that 3ds max uses.
At some point I had similar issue, but I think in my case it was the different transfer speeds between the nodes, the end result was clean but during progress render I saw different brightness.
Oh. I looked at the image wrong. I thought the issue is this big white area. Yes, it’s also worth checking if the difference doesn’t go away after some time.
Im getting the same in my renders, im new to Corona after many years with Vray, i must say i love Corona BUT this DR darkness issue is Driving me crazy.
Rendering locally all is fine correct brightness, but render with 10 Render nodes the images becomes very very dark and sometime with lines!
There isnt a Gamma issue as these are new installs of just render slaves and the Gamma setting come from the machine that sends the job surely,
Please fix this issue as i can see the potential and want to roll it out in my studio but cant with this issue at present..
It’s a textures network path related problem. Some of your dr nodes cant get acces to textures and render black, resulting in darker lines in your render. Resolve path to UNC location in 3dsmax asset tracking menu does the trick for me.
Thanks but i don’t understand this gamma thing, if i send a job then it will take on the sent Gamma settings, thanks for the debug tip … will try it ..
