hi guys im verry quite bad about the distributed rendering issue, im sure that in this issue some people can help me.
first can you tech me how to start when doing distributed rendering?
ive try it by the help of manual but it doesnt work..
when i start to render it theres some issue to be solve
first in vray render progress says that the render host is not responding
second only one bucket will appear on my scree
Are the machines you are trying to use connected together by some sort of LAN? Also - make sure there is no firewall blocking the drspawner on the other machine. I believe the official 1,0 release of VfS uses port 20204 or 20205 - the latest beta builds are using 20212.
joe thanks for the quick reply,
my machines are both connected via lan in a router
then all PC are firewall block
where i can configure the port? in the router or in both PC?
