Hello, I am trying to do some distributed rendering with my laptop, but am met with this error. Any idea what might be causing it?
- I have 3ds max and Backburner installed on both machines
- I find my laptop in max interface on manager
- Laptop registers on backburner successfully
i have the same problem, but i use 2015 max version, while if I use the 2013 version on the same pc there is no problem
Still had problem when remotly launching DrServer.exe
It seems that it is a working directory issue while executing the exe.
Here is a command line workaround :
start /B /D “C:\Program Files (x86)\Corona\DrServer” DrServer.exe
great, I just tried it and it works, thanks
so deleting the config file helped? Did you delete/install some 3dsmax versions?
I Just delete the drdata folder, Nothing else
I mean, before it stopped working
I’m sorry, I did not understand what you’re asking
now I have a new problem, the netrender with max 2015 doesn’t work on windows8, I tried with backburner but doesn’t work
