Distributed Rendering over the Internet
What I do is I use teamviewer to connect either from work to home or vice versa. Works like a charm, though it lags a tiny bit sometimes with scenes of +10 000 000 polygons. You have all the assets you need, where you need them. It’s easy and fast. And you can copy paste between both computers, which is nice.
You could also use a Dropbox folder on both/all machines as your main project folder, so automatically any files you are working on, including renders being dropped in, will automatically be available to all machines on the fly. I have fibre broadband at home and in the studio for this reason, when I need it.
depends how fast your internet is. We had issues a long time ago when we only had 100/100 lan speeds.
I have Hamchi installed and am able to see my work PC under my network but I cant get backburner to recognize it.
Could someone that has successfully got this to work guide through the steps?
I noticed there are 3 options for Hamach “Gateway Net working” “Hub-and-Spoke Networking” and “Mesh Networking” which one should I be using?
I would really appreciate any guidance.
Thanks!
i don’t remeber the gateway settings (i left it to default)
what you have to do in the backburner servers and managers, is to use the IP addresses of hamachi
and that on all you servers/workstations
it should work fine !
I use mesh…copy the Ipv4 that you have for your BB manager and use that Ip when you send the job in max…go the settings and use the IP in there.
You should be able to see all the render nodes.
