Distributed rendering paths
What would be the easiest way to convert a scene which was done without DR on mind into a DR suitable one. I have a lot of scenes which are using textures from all over the place, and none of them is mapped to a network drive. Is there an easy way to collect them all and map them so they work with DR over the network?
Hi
You can just rescource collect all the maps and the ies files and max will dump them all in your specified place and re-map for you. this can be found in the utilities tab in max … then click more to find the rescource collector.
Natty..
