I’m running Vray 1.50 on VIZ 2008
I’m trying to get my Vrayspawner90.exe to work but, VIZ keeps opening and closing when de spawner is started and DR won’t work.
I’ve created the vrayspawner.ini
I’ve tried the DR viz2006 trick of using a backburner max and xml file.
my vrspawner.log notes the following:
0: [2007/Oct/10|12:05:45] ========================== Starting new session ==========================
1: [2007/Oct/10|12:05:45] Got this module name: C:\Program Files\Autodesk\VIZ2008\vrayspawner90.exe
2: [2007/Oct/10|12:05:45] Got this INI file name: C:\Program Files\Autodesk\VIZ2008\VRaySpawner.ini
3: [2007/Oct/10|12:05:45] Reading settings from INI file: "C:\Program Files\Autodesk\VIZ2008\VRaySpawner.ini"
4: [2007/Oct/10|12:05:45] --
5: [2007/Oct/10|12:05:45] Dumping current settings...
6: [2007/Oct/10|12:05:45] VRaySpawner temp dir: ""
7: [2007/Oct/10|12:05:45] Application name (MAX/VIZ): "c:\Program Files\Autodesk\VIZ2008\3dsviz.exe"
8: [2007/Oct/10|12:05:45] --
9: [2007/Oct/10|12:05:45] Process id is 2716 (0xa9c)
10: [2007/Oct/10|12:05:45] Executing ""c:\Program Files\Autodesk\VIZ2008\3dsviz.exe" -server \vraydummy90.max"
11: [2007/Oct/10|12:06:17] Process id is 2716 (0xa9c)
12: [2007/Oct/10|12:06:17] Executing ""c:\Program Files\Autodesk\VIZ2008\3dsviz.exe" -server \vraydummy90.max"
13: [2007/Oct/10|12:06:47] Process id is 2716 (0xa9c)
14: [2007/Oct/10|12:06:47] Executing ""c:\Program Files\Autodesk\VIZ2008\3dsviz.exe" -server \vraydummy90.max"
15: [2007/Oct/10|12:07:21] Process id is 2716 (0xa9c)
16: [2007/Oct/10|12:07:21] Executing ""c:\Program Files\Autodesk\VIZ2008\3dsviz.exe" -server \vraydummy90.max"
17: [2007/Oct/10|12:07:49] Process id is 2716 (0xa9c)
18: [2007/Oct/10|12:07:49] Executing ""c:\Program Files\Autodesk\VIZ2008\3dsviz.exe" -server \vraydummy90.max"
19: [2007/Oct/10|12:08:21] Process id is 2716 (0xa9c)
20: [2007/Oct/10|12:08:21] Executing ""c:\Program Files\Autodesk\VIZ2008\3dsviz.exe" -server \vraydummy90.max"
21: [2007/Oct/10|12:08:53] Process id is 2716 (0xa9c)
22: [2007/Oct/10|12:08:53] Executing ""c:\Program Files\Autodesk\VIZ2008\3dsviz.exe" -server \vraydummy90.max"
23: [2007/Oct/10|12:09:05] ========================== Ending session ==========================
there’s nothing wrong with the xml, as far as I can see…
does anyone have the answer to my problem?
