Distributed Rendering problem with Forest Pack
Hello.
I noticed that when using Distributed Rendering (LAN connection) with Forest Pack, scattered objects become semi-transparent… It also affects the render element passes. Plus, Wirecolor Pass doesn’t assume the assigned color to the Forest custom object.
Scene in the attachment was created in Corona 3.1
You are aware of the fact that you have to install all plugins (here ForestPack) on all render nodes? Additionally check asset paths with the assset tracker.
Good Luck
Thanks for the reply.
Indeed, i dont have the forest plugins installed on the slaves. I’ll check that.
