Just built a new machine as render slave. Im using V-Ray 2.50.01 and Max Design 2015.
Backburner successful rendered a frame to this machine with no problem.
But Rendering as a Distributed rendering machine fails to display any buckets rendered from this machine.
VraySpawner2015.exe is running as a service in “Running” mode.
I do see VRayDummy2015.max on my taskbar.
The host machine does say "Using 1 hosts for distributed rendering. Server *.*.*.*. Scene loaded; starting render.
I’ve also told windows firewall to allow 3D Max, VRrayspawner to bypass the firewall.
Scene beginnings rendering but I’m not getting any buckets from new machine. Any suggestions?
1.Create a completely new scene with a few basic primitives and a few lights. Make sure that the scene doesn’t render super fast, otherwise you won’t be able to see the buckets.
2.Start VraySpawner manually, not as a service.
3.Turn off firewall temporary(only for the test).
4.Make sure that the V-Ray license server is configured correctly for both (workstation and slave) machines, and you have at least 2 render-node licenses.
5.Run a test render with DR enabled.
6.If the slave machine does not join the redner, please copy both V-Ray log files from the workstation and slave machine and send it for investigation.
After creating a new scene, I do see the slave machine helping render the Master scene with DR. I turned the firewall back on, and it continues to help render. So the issue must be with my architect scene? I would like to send a log file of this scene, but I can not find an output of the log file. The manual says it is saved in the root if C:\? Is that accurate? Where can I find the log for both master and slave machines to send to chaosgroup?
Would you please try to update your 3DSMax to the latest available Service Pack.
Then make sure that VRaySpawner service is configured to log on with a real-account not with local service account as it is by default.
Run another test and let us know if the issue is still there.
I already had the latest service pack for 3D Max Design 2015 installed (Service Pack 2). As for user accounts, I basically have two accounts for the slave machines - “Renderfarm”, “Administrator”. Are you suggesting that I need to change some type of security settings on my “Renderfarm” account? I assume this is behaving in the “local service” mode that you mentioned. Not sure how to get run VRaySpawner service as a real account.
By default when VraySpawner is registered as a service it uses Local System Account.
Local System Account however has some limitations and it is recommended to use another account type that has the necessary rights.
My VraySpawner is fully running as Administrator. Still isn’t working. I’m emailing support@chaosgroup.com right now with log files and screenshots.
Edit:: After more test with a quick sample scene that works, I’ve noticed that the textures do not render on the DR Slave machine. But it renders as a Backburner Slave with the textures just fine. Could this be related to my issue? I do not know what permissions need to be changed since it renders textures just fine as a backburner slave.
Missing textures on the slave-machines basically means that the spawner doesn’t have access to the textures and yes it is most probably related to the same issue.
There are several reasons for that:
1.Firewall
2.VraySpawner is launched with non-administrative account.
3.Mapped Driver paths are used.
Please turn off Firewall temporary just for the test.
Log on on the slave machine with administrative account and start VraySpawner manually, not as a windows service.
Change all the paths in the scene to use UNC convention and avoid any mapped drives.
Run a test render with V-Ray DR between only 2 machines (workstation and slave) - and send us the log files for investigation if there are any issues.
Hey, I have the exact same problem. Running Vray 3 build 3.15.01. 3ds max 2014 SP5, Windows 7x64
Backburner works fine, all textures present.
DR renders with no textures.
Firewall off
Antivirus off
Textures located on mapped network drives (UNC paths) on workstation machine, can be seen from all slave nodes. (Obviously as BBurner works)
Only seems to have become an issue after updating from the previous build.
Any ideas on this? I’ll forward my log onto support as well
Hey guys, Just to let you know Vray Support advised me to not use my saved render preset (basically I just deleted my maxstart.max file which was setup with previous build of Vray 3)…and it has resolved my issues! All textures can now be seen by all slaves.
