Distributed rendering
Hi, I want to connect to pc’s to render mostly still renders.
-Do I have to make the connection with backburner?
-If I’ll make a local connection and enable the distributed rendering from render setup menu and enable the search LAN button will it found the second computer?
  • Is there any tutorial for distributed rendering with corona?
    Thank you!! Is very important!!!
Yes if they are on the same network.
Have not seen but there is a lot of explanation here on the forum
You don’t have to corona will do it itself just make shure that the dr server is runing on the slave PC and Slave pc have acses to the folder (network drive) you are using for the rendering.
PS - don’t forget to swith regular file locations to UNC file locations in the asset tracking section fo 3dsMAX
Thank you !!! I really appreciate your answer!!!
No video tutorial yet (I guess it would be very hard to do anyway :smiley: ), but check out this guide:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000501666
You may also want to take a look at this category:
https://coronarenderer.freshdesk.com/support/solutions/folders/12000000629
Generally it is a good idea to search for articles on our helpdesk, and in case you cannot find a good solution - contact us over support: https://coronarenderer.freshdesk.com/support/tickets/new
Thank’s Maru!! really helpful!!
After one million tries I can’t resolve this matter…I made the connection I find the slave pc its faster about 25%, I made a network drive I can access it from slave but I have problem with the asset tracking… it cant find the textures, I made the change to UNC but still can’t find the textures… Anyone with same problem?
Thank’s!!
