I have big problems getting DR stable.
1. Vrayspawners still need to be restarted after a rendering was canceled.
2. Sometimes the Hosts fail on a second rendering even when the first
wasn´t interrupted.
3. I make a little test scene save it on a network drive, render with DR
and the “Transforming Vertex” Phase takes nearly 3 minutes.
(Just a plane and a sphere)
4. I have one machine that doesn´t want to render DR at all.
Same installation as on the other machines (max7, no7.5, vray
1.47.03).I add it to the server list, resolve server shows me the
machine. But as soon as i hit render it doesn´t do anything.
Not even a “Render Host Failed”. The vrayspawner log file entries are
the same like on the machines that render correct
5. I had a DR in progress. All machines that should, were rendering, and
about at the middle of the rendering i got “Render Host Failed” Messages
from all machines and my local machine was the only one left rendering
the image.
Probabely most of these problems are network related.
Any solutions/ideas what can be done about that ?
Thank You
ps. always tested in Irradiance Bucket Mode.
