Hi guys,
I’ve been wondering this for quite some time and haven’t found an answer on the forum yet. If there is please forward me to it.
So my question:
Is it possible to run the render through corona’s native distributed rendering only on nodes - not on master pc?
Let’s say I need to work on some other file/other software so I need the PC computing power, but starting render on node takes a lot of time, reliking bitmaps has some issues sometimes etc, graphic card has trouble handling large scenes or so.. I hope you get my point.
I have done this.
On my master comp in 3dsmax I set up DR to use only nodes2-3-4-5.
Then I submit the file to be rendered in network rendering, backburner.
From Backburner I choose only to use Node1. Then that comp receives the file and
nodes 2-5 will render it with 1. And my master comp is free for me.
Using Backburner or some other management tool like Deadline is one option.
Another one (but honestly I am not 100% sure if it will work) is saving the rendering “job” as a .bat file using batch rendering, and running it on one of the nodes.
