Ditributed clients stop working at the 8th frame
I am new to Vray5 (used 3.7 for many years). unfortunately Vray5 doesn´t support teamrender.
My Problem: Distributed rendering makes problems every 8th frame. The clients stuck, 1-2 frames are extreme slow, then all clients stop working and only the workstation keeps rendering.
I stop rendering, start rendering 8 frames further, same procedure.
Tested on two different workstations on two different places with very different network enviroment.
best regards, Dirk
Hello @dirk_laggner ,
Can you specify the exact version of V-Ray that you have installed both on your local machine and on your servers? Which OS are you using? Does this happen with any scene or a specific scene only? If it only happens with a specific scene, please send it to us (with all assets for it) so we can have a look.
Do you experience the same issue if you don’t use the local machine for rendering? Also, do you get any warnings or error messages?
Thank you.
