often my clients ask me for realistic looking people in my still images, but in the right pose to show a design object or a function. I would like to use the people from here:
but I don’t knowed a software to set the right poses, a software that is not so expensive like 3dsmax or lightwave. Now I found a free software that allow to rig a model in the right pose - Animeeple. Attached a screenshot, I set the pose for an airplane seat (simpliefied model loaded to animeeple).
Anything works quite good, but … I can’t save the pose, only the model and the animation (can’t read by Rhino or SketchUp). I ask the developer of Animeeple and got the answer:
Thanks for your email. I’m sorry, but so far, we’ve only gotten your request for this feature, so I’m not sure if there is enough demand for it such that we could even recoup the development cost. We appreciate your suggestion though, and if we see more demand for this feature, we’ll reconsider it.
So my question - are there user who need a solution like I? Please write here so that I can show this thread to the Animeeple team.
Re: Do you like to get self posed high quality mesh people?
Have you already tried Poser or DAZ Studio?
As far as I know, Poser isn’t really expensive - DAZ comes for free but you have to buy the content. Which isn’t expensive either!
You can save the posture in both packages, I guess.
I’ve got DAZ Studio installed, although I rarely use it. Texturing is a bit tricky but I might play around a little to find a suitable workflow in the end…
PS: DAZ Studio doesn’t look too professional in terms of what they show off on their site (it appears to be a bit of a lonely man’s playtool ), but it’s really good to get a natural pose quickly (lots of predefined arrangements).
I’m looking for photoreal peoples, looking like you can see at the street. For example I like to show an airplane interior, the function of the seat, than this man would be ideal:
Micha this was one of the models from the site, opened in max and very quickly put in a seated position.
The model and textures were then exported out as an obj file and imported into rhino.
Small test render in rhino below. Is this the sort of thing your are looking to achieve?
Mark
Mark, yes, that is it what I want to do. But the problem for 3dsmax is the price! It’s to expensive for rigging a mesh man every few weeks. But doe’s 3dsmax allow to import the mesh with bones? Or is an additional plugin needed? Could I use an old 3dsmax version?
If the “save pose” option could be enabled, than this could be done for free or very little money. I’m curious to know are there more people who would find it useful?
Marko,
please tell me how have u exported these “person” or “pose” (i dont know exactly what is pose(r)…sorrY) to Rhino. It came WITH textures of the max file? What kind of object did u create? I mean, wich extension? I m asking that because i tried to import some 3D max blocks (Archmodels with textures and models), saved as .3ds, to Rhino. I couldnt import some trees for example because it was too heavy. And the textures, if i am not wrong, didnt come as well. Do you know some way to solve this?
I’ve also downloaded that guy Marko shows above for a scene that is under development. He’s going to be my DJ
Therefore, I downloaded every programme I came across, installed Anim8or, Blender, Animeeple - literally everything. And after all. I ended up with the 3DS Max Trial version. :-\ …700MB download - bring it on!
I’m not quite happy with what I found out, but for the next 30 days I’m save
How do pose a figure:
You need a software that is capable of handling rigged models. Such as Poser, 3DS Max or the like. This is what this thread is basically about. There, you have a bones structure linked to the geometry that lets you modify the model (often with certain constraints to allow only realistic deformation).
How to get all this into Rhino:
Rhino can read mesh file formats such as .3ds, .lwo or .obj which can be exported from the Character Animation software package.
How to get the textures right:
As .obj files contain proper texturing information, you just need to make a V-Ray material with diffuse/bump/whatever layers that come as bitmap files with the model, apply it to the object and there you go!
In this case, the head has got a separate texture. So you have to explode the mesh and assign the head texture as a separate material. Still, the UV-information does not get lost and you don’t need a special mapping channel.
Hope that helps
I just thought that it should be possible and a rather simple thing to set up a plug-in-like tool for Rhino to handle rigged models. Deforming a mesh is not a super complicated operation, is it? Only: who could do the programming?!
I mean, this is one of the things quite a few people are struggling with - so maybe there’s a market! I’d buy it…
Hi Micha, yes very expensive way to get the occasional model from max to rhino, but there may be a way we can do this.
I have max 2010 (upgrading to 2011 soon) but I have the ability to export the licence from one computer to the other
this is called "licence borrowingâ€. So I believe I could set this up that I could let you borrow the licence when you wanted
to do your people models from max to rhino. I would set up a time scale of say a week or more to give you some time to
export many poses for use with rhino. I will look into this and see if its all legal, if so you are sorted with a way to do your
model import / export for use with rhino.
Max imports all the bones for moving every part right down to all the finger joints
Arturmf
I think Matthias has covered your question very well.
Mark
Hi Matthias, I find exporting as an obj file works well, as you said it takes all the textures with it. I find exporting as 3ds a bit more problematic.
Mark
@Matthias: great that you tested all this software - what do you think about Truespace? It’s free and allow mesh animations? Doe’s it support FBX with bones import? If you dodn’t test it, I would test it here. The 3dsmax demo is a good way too - with my slave computers and the computers of my family I have a lot of computers for it.
@Mark: Thank you very much for the offer of "licence borrowingâ€. Seems to be a great feature. I think, the demo workaround will help me for the next time.
Could somebody tell, what are the key steps for the 3dsmax workflow? Open the FBX in 3dsmax - where can be found or enabled the control for the skeleton? Or is an additional plugin needed?
Micha yea, use that Max Demo on every single computer of yours!
I’ve given Truespace a try just now. Unfortunately, I didn’t find a way to import the .obj file. It says, I should switch from Modelspace to Workspace, but the flag isn’t there ???
If you get it loaded, please tell me!
Because apart from that (and playing around with the rigged models that came with the download), it looks pretty well!
3Ds Max workflow:
The models from the site you mentioned come as .max files
I opened the .max file in Max, the skeleton is attached to the model straight away.
Not sure about .fbx import, there are points in the model but you can’t use them as bones - haven’t figured this one out yet…
@Mark:
Right, exporting from Max as .obj makes for an easy transfer! How is the re-texturing in Rhino when exporting as .3ds?
Truespace wasn’t free in the past (600$), but since Microsoft adopt it, it is free. It can be used to create content for Virtual Earth (Microsoft) and … . So, it’s like SketchUp and Google Earth.
Nice Job Matthias…
about Micha´s work and knowlegde i wont even comment. I wonder when i will reach your levels…but i am learnig fast. Soon i think i can post, in gallery, something.
Matthias: just to make clear about “.obj” issue: the textures of Max´s Vray come WITH the model to Rhino? or just the UV coordenates? because (maybe because my vray for Max is “in Bug”) my imported model in Rhino didnt came with textures.
