Hi.
Setting the Count Multiplier of the foam to even 1.05 stops rendering the foam. Is this a corona thing?
I ran a splash/foam sim overnight (using resim) and thought I’d try boosting them a bit..
Here’s a video - it includes Corona IR processing the render etc - you may want to skip through in parts
Hey,
Could it be that you run out of RAM? Does it reproduce if you try the production render and not an interactive one?
Hi.
My RAM is at 19gb (of 62)
Getting the same issue with production render too.
Not sure if it’s a bug so should I collect the scene up and add a link here? Or does it need to go through Chaos Support?
If I do send a scene, I’ll send a few cache frames. Will me sending frame 150-160 work or does it need to be from 0 ?
Yes, sending the scene would be great, seems to be working correctly with a simple scene I made.
If it’s nothing confidential, attach it here with a few cache files (no need to start from 0). Just make sure to use a zip file otherwise the forum won’t accept it.
Thanks!
Here’s a link:
The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
Using Max 2019
I’ve hidden the splashes shader & have the foam multiplier set to 1.
Thanks again
Thanks a lot for the scene, reproduced it here as well. Will let you know when we have more info what causes it.
