I have just installed a trial of the commercial Renderer but after the installation process I cant see it in my renderer options. I have restarted my computer already but that doesnt seem to have changed anything.
Yes it does. I’m on max 2014 design and Corona is working just fine. Maybe try to reinstall Corona.
Hi. Yes it Works with Max2014 (I use it myself).
From what you write, it seems like Corona isn’t properly installed. So try to install it again, and see if it works. If not, maybe you should check that your virus protection system haven’t blocked/“eaten” Corona (has experienced this with some other plugin).
I would recommend using the uninstaller (it is bundled in the installer) and the using the “just unpack” option in the installer. After that, you can copy the files manually into your 3ds Max root.
maybe double check when you installed it that you chose max 2014? not sure if it auto detects or not but i only ever leave 2016 checked as that is what i use.
