I almost never use the Light Cache -- I usually do single bounce Irradiance map rendering to save render time. Since I rarely use LC I’m confused on how to best implement it now.
There is an OLD tutorial in the Vray manual about rendering a walk-through animation. It seems to have some irrelevant information now since it doesn’t mention the Use Camera Path option for IRR and instead uses Multiframe Incremental. It talks about pre-calcing the IRR and LC and then reload them for the final pass… seems straightforward.
But there is another tutorial in the manual which seems more recent and it covers moving objects. In that tutorial, it says to pre-render the IRR and LC and then on the final pass, that you should turn OFF secondary bounces and just load the IRR map in the first bounce. I don’t understand that. Why wouldn’t you load the light cache file you just created? Is it somehow merged with the irradiance map?
On the walk-through animation, you DO load the LC for the final pass (which is what I’d expect) and on moving objects you don’t -- so I’m wondering why there’s a difference between the two methods?
