why doesn’t the RTX card work in versions 2.7?
Version 2.7 preview 3 has been released, but I still can’t start Enscape.
at 5% my sketchup closes.
I have the same problem when run it with HDRI
It works normally when I use the sky of enscape. but when loading HDRI, the bug immediately. I have tested it on both RTX2060 and GTX1060
Ok, I will test.
Hi @Elnata_Fernandes that’s unfortunate to hear. However it’s great that you’ve reported the issue, did you send your logfiles via Feedback button yet? This will allow us to better look into the issue and hopefully resolve it for the final 2.7 release! :thumbup:
thanks, @Clemens_Musterle
yes I sent the log file
Hey @Elnata_Fernandes we’ve had a look at the log files and in fact it turns out to be a too large custom skybox file. We’re working on a fix for this at this moment, in the meantime you might want to reduce the resolution of your skybox file or disable it and see if that helps ![]()
Ok, I will test.
