try to get the new version of shave to work on our render farm. we use stand alone. everything renders but no fur
im assuming it only works with batch rendering can anyone confirm this?
do any plug-ins render with vray stand alone? just curios how this works do plug-in’s get included in the vrscene translation?
Yeah, im having the same issue. I have all the shave vray dll installed, so it renders fine in maya, but once i convert it to a vrscene (which is what we use for our farm too), no fur.
A basic question first, have you installed the plugin on your render nodes?
It should work fine as shave has a corresponding plugin for V-Ray Standalone.
However from what I remember, it could be that the hair description itself is stored in some additional .dra file, which may be missing from the render slaves. I’m not sure about this though - Joe Alter would be able to say for sure.
yes
Even testing locally, where it works fine in maya, i can’t get the fur/hair working in vray stand alone.
yes its installed on the nodes and I also did a local test and no go with that either. I put in a ticket with Joe about this he thinks it a problem with the way the Vray integration was designed on his end.
