Doesn't save the Irradiance Map
Vray 1.5RC2
I use IM as 1st bounce and LC as 2nd.
I’ve launched on the net a single frame on a single pc, with autosave for both IM and LC.
Well, LC was saved, but IM wasn’t.
I did some tests, with others pc, and it’s always the same: LC saved, IM not.
Is there any tip I should know?
Thank-you!
Will check that, right now. Thanks for the info !
nikki Candelero
It works fine here.
nikki Candelero
…I’ll check my file.
Thank-you
