I wonder if someone experienced that already. I think that if I wanted to create it, I never could.
Using Maya 2019.3.1 , Vray Update 2.2, and PhoenixFD 4.00
Simple scene with Phoenix ocean, HDRI dome light and aerial perspective. This happened when I rotated the camera inside a group to 90°.
I tried to rotate the HDRI, but this doesn’t change anything.
Bug or hidden feature ?
I have to add that I had a Vray sun before in the scene that was deleted afterwards.
I can’t seem to reproduce the issue. Could you attach the scene here or send it to support@chaosgroup.com so we can take a look? Mention this thread in the e-mail.
Thanks. Scene sent to support.
Thanks for the provided scene. It seems a VRayAerialPerspective without a VRaySun has a default location (half of the environment), hence why rotating 90 degrees reveals a portion of the backside (it is noticeable without a camera as well). Note that VRayAerialPerspective is designed for use with VRaySun. Adding a sun is necessary and resolves the issue.
Thanks. I was aware that Aerial Perspective needs a sun. I would have expected that Aerial Perspective gets ignored when you delete the sun. That’s why I posted… It’s only an unexpected behavior from what I understand.
you can put in a sun and turn it off, just make sure that the sun is aligned with the sun of the HDR, then it works somehow, not 100% but …
Yes, just align the sun with a chrome sphere, you can match almost 100%
thanks guy. I was putting a sun, but didn’t try to turn it of and keep the aerial perspective. Sure, matching the sun with a dome using a chrome sphere is the way to go.
Awesome. I just found this and immediately solved my newest problem that I thought was going to irritate me
Thanks!
Down underexpose the HDR until the sun is a sharp dot and align the sun “directional light” in IPR.
I just eyeballed it and it seems to work fine but thanks, I will certainly do that if it goes wrong.
In theory if the sun is directional, would it really need to be exactly positioned if its shadows are not used?
If you have a sun than you have shadows, if the HDR is high quality and casts a hard shadow you might not need to position a source light.
Oh yeah sure…but I thought this was about the aerial perspective ‘needing’ a sun (but turned off) in order to work when using a dome with an HDRi.
So what I was meaning is I just eyeball the sun’s position so it’s close enough to whatever HDRi I use.
Its general angle definitely makes a difference in the shading of the aerial perspective but doesn’t seem to need to be ‘too’ exactly placed, in order for it to work
