Hi, support have pointed me to this thread… I have this issue with normal vray lights… Are we saying v-ray has fundamentally changed and that glossy reflections can no longer be removed by unticking affect reflections in a light?
Therefore how would I now add a light that either contributed to specular only or reflection only?
This is the current behavior for now, however, we are considering other options to produce a behavior similar to the previous one. @ali_cgi , you may try to turn off the reflections from Trace sets (right-click on an object > V-Ray properties > Trace sets) by excluding the objects affecting reflections.
Hi thanks for reply…however i think this change is a huge step backwards in flexibility and ease of use… I really hope chaosgroup change this… these options are vital in a lot of people’s production workflows.
Its a little shocking there hasn’t been a warning about this change. ‘Unless I have missed something’
Removing reflections or spec on a per object basis is unfortunately not a solution. I want the object to receive reflection but just be able to exclude certain lights from reflecting in it.
Basically the old behaviour was ideal and gave more control.
The only solution for me is to not upgrade to version 5 and carry on with Vray Next until these things are reimplemented / fixed.
Please, can you change that to the old behaviour? Now in VRay 5 its impossible to have some texture for lighting and then have something different in background/environment. Because reflective objects with glossiness 1 reflect BG texture and objects with 0.6 reflect lighting texture. Or is there any other way? I think this is really weird decision and we cant do what we can without any problem in VRay 4. Or am I missing something please? Thank you.
We’re staying in v4.30.00 because of this. We prefer to use a combo of HDRI for diffuse/reflect indirect lighting, plus VRaySun for diffuse/specular direct lighting. That requires us to strip the sun out of the HDRI, which Affect Specular does in 4.30.00 (but not in 4.30.01+)
This change seems to have been made to solve inaccuracies in dome light reflection, but it unfortunately breaks our workflow.
There are some updates regarding the dual Dome light setup possibilities: we’ve now added support for additive Dome lights, enabling users to use one Dome light for illumination and another Dome light for reflections, as shown in the visual example: http://ftp.chaosgroup.com/support/sc…4_11-07-39.jpg
Note: the update will be released with the next service pack.
thank you for update. I’m sorry, but I don’t get it. What is new in this setup? We could use diffuse in one dome and specular+reflection in second dome earlier. But problem with this setup is that specular should be ticked on diffuse dome light, not the reflection dome. I need diffuse+specular in one dome and only reflection (with visibility in background) in second dome. But this setup doesnt work. Now it is working? Thank you.
Hi, I’m sorry but that doesn’t seem to be a solution. Actually that is also possible now or?
It should be that specular is treated seperate from the actual reflections, so that you can have specular and diffuse from one domelight, and reflections from another domelight. Basically just like how it was before. Specular and reflections should not be linked. The way it is now it just doesn’t make any sense. You have an affect reflections checkbox that only has an effect if your material glossiness is below a certain treshold. It also makes it very weird to use materials that have maps in the glossinessas you then suddenly you get black spots everywhere where the glossiness is below that treshold once you disable the affect reflections. The new way is a huge step back in terms of flexibility and in fact some super basic setups are not even possible anymore now without having to give up on specular contribution entirely which produces an inaccuarte rendering. So far I didn’t see any particular benefit on why it was changed. Simple basic setups don’t work anymore and you loose a ton of flexibililty without any apparent benefit.
