Dome Light Z/Y up issue
we updated our Vray version to this one:
[2012/Aug/29|14:28:47] V-Ray: V-Ray for Maya version 2.10.01, revision 22263 from Jul 20 2012, 02:17:45
[2012/Aug/29|14:28:47] V-Ray: V-Ray core version is 2.00.01
Now the dome light keeps rotating when rendering on our farm.
This is due to the fact that our farm has Maya install as default (with Y Up) and we work Z up.
Even while using the “Use Transform”, the light gets rotated
Has something changed in this version as the previous version was fine? and is there a way to force vray to work Z up?
Will it be fix in newer version?
thanks
Yannick
In render global --> vray ---> Misc. You have “up vector”. Set it to Z up.
thanks but it is missing in our version. There is a Sun Up vector but that’s it.
I guess must be a version that had something change the up vector not implemented…
Cheers,
Yannick
I installed the last Stable and I can see this in the change log:
Add an option in the V-Ray render settings whether to take the up axis from the Maya preferences, or to specify it explicitly - resolved.
but I can’t find the option.
Any one from Chaosgroup?
thanks.
Add this in python acces :
import vray.utils as vr
for i in vr.findByType("SettingsUnitsInfo"):
	i.set("scene_upDir", vr.Vector(0.0, 0.0, 1.0))
from another thread I got the python code, i tied it in the Post translate python Script but that didn’t work
Cheers.
	print i.params(getValues = True)
Add this code and tell me what the code “print” when you render.
Thanks for the pointer; will fix this.
Hi Vlado, Can you let us know when it is fix. Currently we are rendering on our local machine and cant use our farm.
Cheers,
Yannick
Hi Vlado,
any update regarding this issue?
Thanks.
Yannick
