Uploaded scene to FTP, filename “Invisible_Domelight.zip”
Setup:
Simple scene, VRayPlane as matte groundplane, TorusKnot object with metal shader, a single domelight with a texture (HDRI) and a vray camera
Software:
3ds max Design 2014 SP5
VRay 3.30.05
Issue:
The “invisible” checkbox seems to have no effect when rendering from a perspective view.
Steps to reproduce:
1) Open Scene
2) Maximize the Camera viewport, hit Render; RT will start and show you an image where the HDRI is visible in the background.
3) Stop RT, change viewport to a perspective viewport, hit render again; RT will start but won’t show the HDRI in the background.
This setup is with VRayCamera exposure enabled, so not a “classic” HDRI setup in that way, but it should work. Anyways, you can check the uploaded scene.
