I received .rtu file to update my dongle for 2.0. What do I need to do to update the dongle?
I asked same thing earlier, so:
(*) Make sure WIBU-KEY drivers are installed and dongle is plugged in (must be the same dongle for which the .wbc file was produced);
(*) Double-click the update.rtu file to transfer the data to the dongle.
Thanks Lars, should I install vray 2.0 before updating the dongle?
I don’t think it matters. If you install vray first, it wont find the license. Then you update your dongle and everything is fine again. …should be.
