Door and window models
Hi, Is there anywhere I can get good door and window models, even better if they haveCorona textures on already to go. :smiley: Ideally looking for things like bi-fold and slide doors, windows and velux windows.
Hi, have you checked out the models in the Cosmos library?
Yes I had a look through these, WOuld be nice to have more varaition/options with doors open etc also. :)I guess it doesn’t matter if the models have materials on.
https://www.cgtrader.com/search?keywords=doors
https://www.turbosquid.com/Search/Index.cfm?keyword=doors&media_typeid=2
Search the Asset Browser. You will find windows, doors, staircases, bookcases and other models with very customizable controls powered by an extensive Expresso setup (see attachment). I think you can adjust every item that makes up these models from the dimensions, how many panes, the frames, open or closed. The works.
Yes, you will need to either convert the scene or spend a few minutes replacing the C4D materials with Corona if you want. Technically, the C4D versions will render in Corona, but might not look as good. You can’t always create things with zero work.
