Working in vantage, i imported my vrscene and got to work animating. Had to make updates back in max so exported the vrscene again and reloaded in vantage and now i have 2 suns, and double vray lights in my scene. Does anyone know what causes this and how to fix? Thanks!
Maybe you merged (e.g. with drag-and-drop) the same vrscene file onto the already loaded vrscene file. You can check in the object lister, it would show up as a parent object with the same name as the file and its children would be the duplicate contents. Alternatively, open the .vantage file with a text editor and check if you have both “root_filename” and an item under “imports” pointing to the same file.
