We constantly run into issues when working with files from 3ds Max to Vantage as VRScenes.
Whenever we edit these VRScenes in Vantage (for example deleting a 3D person, a tree, or moving objects), there’s a 99% chance that reopening the file will result in a complete mess.
Is this just happening to us?
Has anyone else experienced problems like deleted geometry not disappearing, or VRScenes mysteriously duplicating inside a file?
Our workflow is to export each 3ds Max XRef as a .vrscene, then create a new Vantage file where we drag in those .vrscenes. When needed, we update them by overwriting the files, aiming to keep everything as clean as possible.
The issue is that when we move or delete objects from the .vrscenes, Vantage seems to keep showing the old, deleted geometry as if it doesn’t update properly. Also deleting entire Vrscenes from the vantage file is pretty much impossible, as they will not go away. They might at first, but they will reappear once reloading the file.
On top of that, if we move the Vantage file to a different folder than the one it was created in, a lot of issues start to appear.
From what you described everything should work as you would expect them and there seems to be some sort of a bug. Can you please send us a scene that is set in the way you described and write some reproductions steps so we can test on our end? You can use the Chaos Help form with a link to the forum thread: https://support.chaos.com/hc/en-us/requests/new You will have to include all asset files.
