Possibility to export a screenshot twice as big as the active view window, so we can change the format of the export easily from one render to the next one. With the existing possibility the resolution is too low.
Option could be like: “Window 2x”
@johann_p Thanks for your feedback. I’ve forwarded your request to our developers.
@johann_p Why is it not enough to set resolution to custom?
Custom is ok, but with the choice “window” we can Change the Format from pic to pic, but only to the Maximum height of about 1080 Pixels…
@johann_p Fair enough - Do you really want “Window 2x” or is it more like “Window aspect ratio, max resolution possible”
Problem with “Window 2x” will be, that it’s possible to exceed the maximum resolution. Neither do I want to bother you with error messages, nor do I want some downscaling without notice.
OK, thanks anyway.
