In the follow page: Renderer for architectural visualization - Corona | Chaos
The link for the alpha v6 is broken. Checking if this is true for anyone else.
For me it points to https://download.corona-renderer.com/builds/3dsmax/Corona_Alpha6.1.zip and gives me a valid Archive.
Good Luck
Is there some way you can provide me with a mirror, because I’m giving a class about it this evening. Just the exe would be amazing.
I have it installed on my machine, but I don’t have the install exe anymore.
Thanks in advance.
Have you tried a different browser? Firefox here and it works just fine.
My guess is that the port (8080) troubles you, not the webclient It´s not the standard http port and your www access may be resctricted when using different ports than standard 80 for http… Happens also e.g. when using a proxy which is only allowed to use port 80.
Good Luck
Yes. It could very well be a problem with port 8080. I had this problem when downloading v1 at work. Luckily the problem was solved by Corona crew adding a mirror link, but materials I had to download at home. Might be an idea to ad a mirror link to all download links? (..or to change port).
