download vismat materials
hey i want to start sharing here if you have material in your computer please share with other until download section open thanks guys.
Here first one from me wooden floor.
http://www.easy-share.com/1911319410/hardwood flooring maple vismat.zip
Re: download vismat materials
here another one black leather.
http://www.easy-share.com/1911319413/Leather vismat.zip
Here wood material.
http://www.easy-share.com/1911319416/WOOD2 vismat.zip
here brick
http://www.easy-share.com/1911319420/brick 1.zip
did you find it useful or you guys just checking my post? No one share their materials i dont understand why?
sooooo kind… Thnx!
no problem i will put more thanks for writing me.
Although I cann’t download your materials, I still thank you very much.
ok i will change links no problem thanks guys.
i checked links working no problem try again pls.
Grass
http://www.easy-share.com/1911319437/grass_vismat.zip
![](http://www.uploadgeek.com/uploads456/0/hardwood flooring walnut_by_miweiler_xl_7015.jpg)
http://rapidshare.com/files/78633362/hardwood_flooring_walnut_vismat.zip.html
aser these are really nice materials!!! did u make it all by urself only with the help of the VfSU manual???
it would be good if u could upload in someother site other than rapidshare… like for example www.4shared.com becoz for some ppl its hard to access rapidshare!! :frowning:
cool no problem guys i will use your website for upload.I am using vray.de materials just converting them but sometimes its hard. Some materials not covertable but anyway i am happy to helping you guys.If you need anything just tell me see u.
I need this copper, i’m trying to recreate it myself but it’s pretty hard
http://www.vray-materials.de/all_materials.php?mat=843
![](http://www.uploadgeek.com/uploads456/0/Mosaic Tiles_by_Parker1_xl_6950.jpg)
http://www.4shared.com/file/32917682/ed0843e8/mozaik_Tile_vismat.html
hi!
are u using the converter to convert these vray for max materials to Vfsu materials?? or are u manually tweaking the settings???
we badly need that material repository back!!!
i am using 3d max materials converting with converter.
Hi! I would like to help in my free time uploading new materials. aser28, how do you use the converter?
I have downloaded some vray materials (.mat), installed 3dmax 9 and the converter but i don´t know how to use it, so if anyone makes an small tutorial of converting materials i would be glad to help you.
Thanks and Merry Christmas everybody!
here you go little tutorial.
1. You need create or load vray mat.
2. Then attach this mat with any objects and right click on object you can see “create vismat…”
3. You can see dialog “mat>>vismat”
or Autodesk\3ds Max 9\Scripts\Startup\VMatEx\readme.txt - mini-tutorial
